Signal Light brake light
AnthonyX99
127
Winnipeg
Hey guys has any ever made a signal/brake 6 volt lights ones to run off the white wire or maybe battery powered. I found a set of signals from zoombicycles but it's only the back and there not that great quality wise.
Venice Motor Bikes
Mar 20, 2008
7,272
1,810
Los Angeles, CA.
Norman makes front & rear lights that run off the white wire... I'm sure it would be easy to make a switch to make it a brake light!!
Send him a PM.
AnthonyX99
127
Winnipeg
thanks for the info the signal lights from zoom bicycles are alright but the plastic that's used is garbage and just snapped off one day while I was riding due.
Outrunner
147
Atlanta, Georgia
You can buy a quality made inline cable brake switch combination
that were used on British made motorcycles. They're listed on Ebay
for under $20 and work flawlessly. They are easy to connect a pair
of brake light wires to, but you will need a battery source, maybe the
white wire could be used.They will not break apart!
