After much deliberation I decided to go with a Schwinn Riverside. It was one of the few, for the price, to have fenders, gears and hand brakes. It's not done yet though. I still have a few things to do and I'm waiting on my hub adapter and sprocket from Manic Mechanic.
From sick bike parts I ordered:
Front motor mount, Motor replacement hardware, spark plug, fuel filter, carb. washers, dual hand brake lever
1. I shortened all of my cable lines except for the throttle cable.
2. Moved the grip shift to the left handle.
3. Removed the front fender mount and made a new one from steel bar. Now it's held on with bolts and lock washers. bolt is hand tightened in the picture.
4. Cut out part of the rear fender to allow the chain to pass.
5. I opened up the bolt holes in the muffler so that it would rotate towards the inside and allow the pedal to pass with 1/4 inch to spare right now. I may open them up a little more.
6. Painted the engine cases black with engine enamel from autozone.
7. Put a little grease on the engine gears.
8. I do not have metal clamping to metal. I used a 1/16" rubber material in between all clamped surfaces.
Hope you guys like it.
Please feel free to ask questions or comment.
