Even though we are in drought conditions in Northern California, There is wet weather ahead, And the bike is stored outside under a tarp.
I need some ideas to make the stock filter water proof or as close to as possible. I've been looking at water proof air filters on ebay but can't find anything for a 60mm inlet, I did look at 60mm-50mm 90 degree gas proof silicon hose, But can't find anything from 60mm-46mm so I can run a water proof filter. I will be using a intake manifold extension tube and have the carb on the right side and the expansion chamber running down the left side, So I can use the tab off the muffler to attach to the chain guard. I don't have fenders yet and until I do I still need better weather protection for this ride. I have also been looking at air boxes for total enclosure, I have the room.
Thoughts and Ideas or proven results Needed.
picture of RT carb and expansion muffler to be put on.
picture of current carb and no space
pic showing how much room I have to work with
I will be spending about 100.00 on my rain suit
http://www.ebay.com/itm/23074076311...49&var=530043961271&ssPageName=STRK:MEBIDX:IT
and helmet
http://www.ebay.com/itm/351193942563?_trksid=p2060778.m1438.l2649&ssPageName=STRK:MEBIDX:IT
on the 1st. and about 30 more on the side case cover, intake manifold extension tube, and a rear engine block and a 515 1/2 link. So I'm pretty strapped for funds so Don't go over board with expensive ideas's please. I'm trying to get rid of the chain tensioner so by buying the rear block and cutting 1/2" out of it I should be able to drop the tensioner and will have the 1/2 link for a back up. Idea's on chopping the block or a url to do it from the forums would be Most helpful.
But I do appreciate the help. Thanks in advance !!!
and helmet
