The AUFFENAUGER lives! A few bugs to work out after the first ten-mile ride, but nothing major.
They're airless-foam filled. My last build flatted a rear tire at thirty mph in spite of thorn proof tubes and liners. I had to walk it the three miles home, and every step of the way I told myself that this could have happened 20 miles from nowhere at 1AM when I was riding it home from work. These seem to be OK, a little squirmy when rolling over grooves and stuff, but they're hardness equivalent is 90psi.I like it I know riding it around here I would be stopped and asked "Is that motorcycle from the 1800's?" lmao
Are those run flat tires? How they working for you?
I have a set myself, be careful I learned the hard way with those tires. Mine after a short time just rolled right off the wheel in a turn. Plus the added rolling resistance just kept getting worse and worse the more I used them. Hope you have better luck then I did.They're airless-foam filled. My last build flatted a rear tire at thirty mph in spite of thorn proof tubes and liners. I had to walk it the three miles home, and every step of the way I told myself that this could have happened 20 miles from nowhere at 1AM when I was riding it home from work. These seem to be OK, a little squirmy when rolling over grooves and stuff, but they're hardness equivalent is 90psi.
These were of the hardest compound I could find, equivalent to a conventional tire filled with air to 90psi. They were a cast-iron bear to install. Lots of Ruglide, leather gloves, plastic tire spoons, whips, chains.......Tubeless Motorcycle tires are a piece of cake compared to these because too much force would cause a bicycle rim to twist and end up looking like a potato chip.I have a set myself, be careful I learned the hard way with those tires. Mine after a short time just rolled right off the wheel in a turn. Plus the added rolling resistance just kept getting worse and worse the more I used them. Hope you have better luck then I did.
** I would like to add that I first installed these tires onto a pedal bike, they never made it to a motorized bicycle.
Thank You! The bars were ape hangers before I sawed the handles off and bent new ones. I kind of used the TLAR (I pronounce it Tee-Lar) theory on them, (That Looks About Right).Just plane awesome Cad. Really beautiful.
Are the handlebars ape hangers? Also, how did you build the frame? Would love to try one. (am wondering about a jig)
Again, beautiful build!
You know, you have just given me an idea for a name. I am building this motorized tricycle see http://motorbicycling.com/showthread.php?t=49598, and just got done setting up the differential so I can run a drive chain from the engine off one side and the chain from the pedals from the other. A Peerless Differential. This Trike's name is gonna be: Peerless Leader!Awesome bike. You should hire moose and squirrel to prevent Boris Badinev from stealing it.
