As an incoming college freshman without a car (and having sold my previous build), I found that everything I needed to commute to was in around a 4 mile radius. I guess I could pedal the distance and get a $500 road bike off craigslist, but the area is hilly and I have plenty of spare time so why not build another bike?
I'm still about as experienced and well-equipped as you would expect an 18-year old with no prior mechanical experience to be, but I'm determined to make this build right the first time by reading the forums and such.
So here's a build log I'll be updating for the next week or two as I receive more parts in the mail:
Day 1 - Sept 12, 2012
I bought a Magna Rip Curl and some parts off eBay about a week back and it's finally starting to come together. The motor kit, at first glance, seems fine cosmetically but it seems I can't mount it without a Sick Bike Parts front mount (that I ordered yesterday) because the U-bolt mount that came with the motor had the holes drilled in the wrong places.
Here's the parts list so far:
BGF Z80 motor kit - $150
Schwinn Springer fork - $50
Generic turn signals - $5
Chain breaker - $10
Experimental chain tensioner - $15 (to my knowledge noone has used it)
NGK B5HS spark plug - $3
A length of 41 roller chain - $20
Bike - $110
Oh well, there's still plenty to work on, so I installed the throttle and clutch lever (relatively simple, they seem to have gotten rid of the metal nub on the throttle that used to make it a bit harder to install) and set on attempting to disassemble the hubs for cleaning.
For being Chinese build quality, the amount of grease in the hubs was an acceptable amount, contrary to many complaints on the forums - there was plenty of fresh-smelling grease smeared everywhere on every surface and I could have probably ridden a hundred or two miles without the grease acting up. Hub disassembly was simple too - it pretty much just unscrewed using two wrenches, no specialty tools.
So now that the hubs are clean, I ordered some more things:
Pyramid MX1000 BMX side-pull brakes (for the front or rear, with 96mm reach) - $20
Some generic bullet light that looked cool - $30
Time to buy some high-temp grease and pack the hubs for the next step, then. I'm not sure the MX1000 brakes will work on the front, with the springer front end and all - but they were the longest reach brakes that I could find and if they don't fit on the front they'll probably fit on the rear.
More updates to come as parts come in. Comments and criticism always appreciated.
Chain breaker - $10
Bike - $110
