I bought the Predator 79cc Harbor Freight 4-stroke engine from the brick & mortar HF here in Kansas City . They were out of 99ccs, which appear to be the same engine except for bore & stroke, and I was satisfied with the smaller 79cc because that seems like an adequate displacement for my ambitions, and the less noise, the better. I paid total $90, using a 20% off coupon and a tax resale number.
I have a rack to mount the engine behind the seat post and above the rear wheel. I'm currently planing on using a 29" Walmart Deception.
My next need is a centrifugal clutch.
To me, it seems a centrifugal clutch with a small pulley (1.5-2 inch?) with its belt going straight to a very large pulley (maybe the size of the rim of the 26” wheel, which is 21.5") would work and give something near a 12:1 ratio. But nobody seems to use that arrangement, so there’s probably a reason.
I’d prefer belts to chain, but what’s the suggestions at this point? The pre-made jack-shaft (like http://www.affordablegokarts.com/mm...&Product_Code=2600&Category_Code=99cc)systems seem a little pricey for what they are.
Anyway, for you experienced builders, do you have any suggestions?
For starters, what are the clutch suggestions?
