I am not allowed to promote what I offer for the perfect solution to your problem in your problem topic as an answer, just suffice it say it say I have one if you can find it.
This concerns me however...
"I also noticed some residue on the top of the spark plug, but I can't clean it off.
And I can't unscrew the plug, it's really in there."
(nods and smiles) hehehe...
I don't care if you have to use a pipe wrench, get that plug out!
Just to rule out some obvious stuff first, you didn't like use LockTight or Teflon tape or something on the plug threads right?
Then provided you didn't use gorilla force to put in there must be another problem, lets just hope it wasn't mis-threaded to start and forced in (shutters).
A plug should finger in all the way easy and just a 1/4 turn with the kit provided plug wrench is all you need, and it comes out just as easy.
Now to plugs...
Funny how these kinds of topics come up when I just happen to be testing the very things being asked.
I love to share here, all I have time for and know something about, but I have to direct you
here for what I have learned and partially tested the last couple of days.
In brief however, the NGK B6HS is awesome and at least in a straight head 48cc, the Tri Spark LD Z4JC stock slant head plug ummm... blows/sucks/bites pick your own adjective.
Same bike, same weather, same gas, same 1/2 an hour time frame, same everything but the plugs. It is just too much to try to keep updated here too as I will start testing in GT5 slant head tomorrow too.
Get that plug out dude!
Do you still have the other LD Z8C the kit comes with?
Gap it to .028, every auto parts store sells the little wheel ones, usually right at the counter.
More later on this here in this topic if I have time.
