My new bike and motor are going great exept the chain rubbing on the frame. The other problem I have is the idle speed. It goes up and down all the time i turn the idle screw up and down all the time to correct it any ideas thanks mick29
I had the exact same problem with the up and down idle . I cured it with a
quality RTV gasket sealer from an auto parts store .Follow directions to the letter. It was made by Permatex or Form-a-Gasket brand sealer for aluminum 700degree heat tolerance I believe .Cost $ 7.00 and a razor blade to clean the surfaces of the intake manifold and the cylinder head where the manifold bolts on .
