D D3s New Member Jun 11, 2016 5 0 1 England Jun 18, 2016 #1 I've lost the small keystock semi-circle piece of metal which fits in the groove in the motor 10t sprocket when i tried to remove the sprocket it pinged off. Where can i buy a replacement/substitute. Thanks
Chaz Well-Known Member Jun 3, 2012 1,004 72 48 Vancouver, British Columbia Jun 18, 2016 #2 I would try contacting the vendor from whom you purchased the kit first. Most of the vendors you see in the sidebars at this site probably sell them. Bikeberry has them: http://www.bikeberry.com/engine-kit-parts/2-stroke-clutch/woodruff-key.html I'd most likely be fishing around with a strong magnet in the place where it escaped. I wonder if LudwigII knows of a substitute? good luck
D D3s New Member Jun 11, 2016 5 0 1 England Jun 18, 2016 #3 Thank you so much i couldn't think of the name! I knew they were in there somewhere
C curtisfox Well-Known Member Dec 29, 2008 6,048 3,959 113 minesota Jun 18, 2016 #4 A good hard where store should have them also...................Curt
