mounting motor on/above top bar - massif fatbike
misterb
9
DFW
Wanted to get some thoughts from the experts here -- what about the possibility of mounting a motor above the top bar on a Mongoose Massif (20" fatbike) by using a longer seat post to make it 'adult sized' like the pic below:
Ideally a small 4stroke and a qmatic if that were possible.
wheelbender6
4,059
221
TX
I have seen it done with a GX-35 clone, but it takes a lot of fab work, jackshaft, etc. I would add a friction drive kit instead to preserve those great disc brakes.
Where did you buy that thing? I want to test drive one myself.
misterb
9
DFW
I haven't picked one up yet - one of the neighborhood boys got one and I was envious :) I found the pic above online. I guess I could live with a friction drive, but only if I could center it - I have a thing for symmetry, can't stand the motors hanging off to one side.
I haven't seen them in stores yet - you can order online via walmart, target, academy sports, etc for < $200
wheelbender6
4,059
221
TX
Offset mounting the engine on a friction drive setup allows you to mount the engine lower, for better handling. The lower cg really helps when leaving and approaching a stop.
If you mount a fuel tank or cargo box on the opposite side of the rear wheel from the engine, you can maintain some symmetry.
curtisfox
6,048
3,960
minesota
Kooool if it were me and realy wanted to do it I would cut the tubes off and make new. Nice curved drops loop and maybe split the top into two out around the motor if needed just my thoughts...........Curt
misterb
9
DFW
I think it IS a steel tube bike so at least it'd be easier than aluminum.
2door
Moderator
Staff member
16,302
175
Littleton, Colorado
Not being a naysayer but I always look at things with safety or the potential for injury in mind. I can't help but think what would happen in a sudden stop with an engine mounted high between your legs. Not a pretty thought.
I'd have to explore another option to motorize that one. Friction or rear rack chain drive would be a better choice, me thinks.
misterb
9
DFW
good points to consider!
misterb
9
DFW
misterb,
Like you were thinking, I mounted an engine to my top tube via a piece of angle aluminum. I run the chain to the large chainring via a front freewheel and then another chain from the small chainring back to a 9 speed cassette. It worked out really well!
Here is the link
http://motorbicycling.com/showthread.php?t=50454&page=13
-Lowracer-
wow - thanks, that's just the kind of thing I was looking for. I actually already have a gx31 I got for about $50 on ebay.
mapbike
5,502
109
Central Area of Texas
In my opinion the only thing that will not totally jack the looks up of that bike would be a nice custom built friction drive set up, anything between the seat post and the handlebars is not gonna be nice looking and I'm with Tom on the safety aspect.
cool looking bike for sure but the engine and drive set upo needs to be at the backif I were doing it.
Here is a set up that would work good on that bike, sets the engine center of the bike, no good up close pix of the design but it wouldn't be that hard to build from what I can see.
http://youtu.be/Ec03Vbd1_yM
misterb
9
DFW
regarding saftely concerns, if i really wanted to stick with fat bike with 7 speed cassette, i could just move to the dolomite (if I can find enough room within the frame):
2door
Moderator
Staff member
16,302
175
Littleton, Colorado
I'm with Curtis on this. If I was going to motorize that bike, and it would be cool, I'd modify either the top or the down tube to accomodate a 2 stroke in frame installation.
That will require some fabrication, tube bending and welding but it would be worth the effort in the end. You'd also have to get creative to retain the rear disc brake but it can be done. Good luck. Let us know what you decide.
mapbike
5,502
109
I was looking at a post about the GX-35 and saw this thread.
http://motorbicycling.com/showthread.php?t=53529
looking at this photo Im thinking that isnt gonna work unless engine is set up to run counter clockwise, unless there is a gear box on the other side that causes the output shaft to rotate counter clockwise when the engine is runnng clockwise... there must be a gearblox that just cant be seen.
2door
Moderator
Staff member
16,302
175
Littleton, Colorado
Yes there was a gear case.
I've ridden that bike, or one just like it, with that weird engine installation. That chain running down next to my leg was scary. I kept imagining it breaking and wrapping around my neck. Not a great idea.
wheelbender6
4,059
221
TX
I was thinking that you could mount a typical beach cruiser chain guard on the motor chain. Then I realized the the chain guard would need to be a left side drive version to work.
mapbike
5,502
109
fabricating a chain guard for that set would be very sime and if I had a bike like that it would dang sure have one, there would be at least one or maybe two guide rollers built into the guard also, a chain that long needs something to insure alignment and correct tension in my opinion, or one wrong bobble during a leaning turn and that chain could come off.
myself Im not sure Im a fan of an engine being mounted up under my chin while Im cruising down the road at 30 mph....lol!
map
lowracer
1,319
Charleston, SC
Regarding my top tube mount, I use a piece of angle aluminum to guard the drive side of the chain more for oil flying up, than for safety since I've never had the engine driven chain fly off. The chain from the BB back to the rear cassette came off once or twice in the beginning, but I fixed that by mounting a larger chainring to the inside of the 24T chainring acting as a chainguard.
I thought about running all chains within chain tubes (similar to a recumbent) but since I haven't had any more derailment problems, I didn't.
-Low-
Bzura
43
PA
You can fit (barely) a HT engine in the Dolomite with a shift kit. I did it, and it's lots of fun. I had to get a longer 5/8 keyed shaft though, but that wasn't difficult to swap out.
