Here you go LR, some pics. Its mounted to the bar clamp bolts with a 1/4" thick bracket(with junk hardware for now). Seems very substantial I sat an 8lb weight on top to sim the fuel load, didnt phase it. It is a good 4" drop to the carb float bowl, leaving no flow issues to the bottom of the tank. Line run will follow one of the cables and will be out of the way. Will add an inline fuel shut off and filter. I dont remember if this is a 1gal or 5qt tank. A gallon for sure. Will actually loose a bit of capacity as I was carrying 6qts between the gas can and the existing fuel tank. Would be nice not to have to add fuel on the road and a full tank is probably 160mi. It looks ok to me as this is a non-style bike anyway. The rack under the tank is free to carry whatever I can stuff under the tank, instead of just a gas can.I will remove the small existing tank. Will probably plug the tank, fill it and ride around a bit when the weather clears to see just how it does.
