Since dismantling the pusher trailer I recently built, This new project started out as a center engine mount using the jackshaft & pulleys to power the friction drive roller. I didnt like the jackshaft & felt like it ate up too much power w/ additional friction, so I simply mounted a BMP roller onto a Staton 1/2" double bearing clutch driver unit. There is definitely much less friction running it directly without the added complexity of the pulleys, pillow blocks, jackshaft & mounting hardware, & so far tire wear seems low (no black dust all over the place). I think the Maxxis Hookworm 2.5 is a good tire for friction drives since its so HUGE. The whole mount took me half a day to build & has a nice quick release to the inside for the up & down roller adjustment. I'll leave it like this for a bit. Maybe beef it up with additional supports, maybe install the expansion chamber & a single speed conversion for the cassette & probably a 32T front chainring instead of the 46 on there now...
-Lowracer-
-Lowracer-
