Ok, so there's a few things bugging me that I'm either not to sure about and some things I jut plain need help with.
1) I've got one of the odder shaped frames to the motor doesnt sit like one would expect it to hence the use of the adapter I alo ordered from KingsMotorBikes.com. Anyway, as noted by the pic, I am unsure of how the chain will be guided to is it concieveable (sp?) for me to instead use a downward facing chain guide be it with or without a makk roller ssprocket ?
2) The downward tube is to large to fit the coil box or whatever it's called so for now I temp placed it on the upper cross bar. Well, the screws that hold it on interfere with the placement of the gas tank as evidence by the 2nd pic. Any of you got an idea or two for better box placement ?
3) The head piece on the spark cord doesn't sit right on the plug. I can jiggle this thing like there's no tomorrow, any one got any really good replacement ideas ? As it sits now I'd be lucky to hold a current for more than a minute.
4) This ones elf explanitory but also requires some thinking. Pretty much the way it sits I can't move it any more / place it any better and as it sits now there's a gap at the motor where the exhaust attaches... not sure how to try and fix this one since I don't have the means to bend the tube down and left I'm thinkin a quarter to a half inch.
It also appears that there might be pedaling issues even if / when tweaked.
