Flared clutch shaft?
FractaL64
55
Canada
The rod and ball bearing that go inside of the thing are really really loose.
How can I replace or fix? Do I need to replace my entire clutch assembly, or can I just replace the nut holding my engine's drive sprocket in place?
crassius
4,032
158
USA
I've seen similar on bikes that weren't greased well at the bucking bar - considered pressing a brass bushing in there, but with several dead motors around here, it was easier to just shove in a used shaft.
Kioshk
1,152
10
Connecticut
This happened to me last year. I made a new bar from a wider drill-bit and greased the heck outta it. It extended the part's life by about 2-months. I like crassius's idea though...sounds viable.
crassius
4,032
158
USA
I would have used some old valve guides that I have lying around, it *should* work well, but it is much too much work for a shaft that is so easily replaced.
