New pipe setup.
jeffyh
53
Madison, NJ
Here's a picture
How well did the hydraulic tubing work? Do you have to replace it often? What exactly is is and where did you get it? I'm having clearance issues with the stock pipe cause I'm using a single speed bike. Trying to look for alternatives and non-metalic tubing would be the easiest. Trying to avoid buying a 7/8" pipe bender and finding someone to weld right now...
Robbie
50
Calgary canada
It works good iam still on the 1st pice. U can still use the stock exhust if u buy a $10 dollar propane torch and heat the tube up till it glows the u can bend with your hand. That's what I did on my first beach cruiser build.
