35 Tooth CNC 7075 aluminum 3 way mount sprockets for sale
When I designed my 2 stroke rear sprocket I settled on 35 teeth
because.......
Stock 44 tooth = 27.9 MPH at 6500 RPM and 26" tires
cnc 35 tooth = 35 MPH at 6500 RPM and 26" tires
35 tooth at 5000 RPM = 27 MPH
35 tooth at 5500 RPM = 29.6 MPH
35 tooth at 6500 RPM = 35 MPH
35 tooth at 7300 RPM = 39.3 MPH (~True redline on a stock 66 cc)
The Chinese 66cc 2 stroke engine does not have enough power to
pull a smaller sprocket than this without losing a lot of bottom end
and it won't go over 40 mph anyway cause it doesn't have enough HP
Speed is not the only issue with a smaller sprocket as you are dropping
1300 RPM at 28 MPH for a much smoother and comfortable cruise
My sprocket mounts with the small Grubee style rag joints and has
a larger center hole diameter of 1 11/16" that matches the rubber rings and clears coaster brakes
It also mounts with the larger diameter PK / Raw rag joints or
can be Clamshell mounted by the large 3 holes
Reversible offset mount 1/4" thick light weight aluminum 7075
Sells for $29.95 for local pick up In Orange County and
$5.95 shipping & handling for 2 day Priority Mail envelope with bubble wrap
Can ship 2 sprockets for only $5.95 total too
Buy three sprockets and get FREE Priority Mail shipping
Sprocket is now engraved with [email protected] & 35T
35 Tooth is the Only size custom sprocket I currently sell
PS: I also sell 2 Stroke Accessories & all the Kit Parts locally in Orange County, SoCal
Copper Exhaust Gaskets $6.95
Billet Clutch Actuator kits $33.95
Short Straight O Ringed Intake Manifolds ( out of stock )
because.......
