TODAY I SKETCHED OUT A EASY DUAL DRIVE SYSTEM FOR SOME TRIKE MODELS. BOUGHT A FEW USED TRIKES, INSTALLED A FRICTION DRIVE ON ONE OF THEM. IT WORKS WELL, BUT TRIKE`S DO FEEL A LOT DIFFERENT.
HAVE HAD THE DUAL REAR WHEEL DRIVE IDEA IN THE BACK OF MY MIND FOR AWHILE. TODAY I STARTED SKETCHING IT OUT ON PAPER TO GET IT VISUAL IN MY MIND. I`M THINKING THE FREEWHEEL SPROCKET WILL LET IT TURN WITHOUT A BIND IN THE TIRES.
THIS WILL WORK NICELY AS A RIGHT SIDE DRIVE ONLY WITH A FREEWHEEL FOR PULL START MOTORS ALSO. AND WOULD BE EASY TO ADD THE LEFT SIDE REAR WHEEL ADDITION LATER AND NOT HAVE TO CHANGE ANYTHING ON THE INSTALLED RIGHT SIDE DRIVE.
IT WILL BE EVIDENT THIS SKETCH WAS NOT MEANT TO BE POSTED. CLEANED IT UP AND WILL POST IT AS I HAVE A HABIT OF NOT RE-DOING THINGS. WILL BE HAPPY TO ANSWER QUESTIONS.
MEMBERS AND GUESTS MAY NEED TO STUDY IT A BIT.
STATON SELLS KEYED ADAPTERS FOR THE REAR AXLES WITH THE KEYWAY. MOST AXLES ARE 5/8" ABOUT $15. EA IF THEY ARE NEEDED. BOUGHT MY HD HUBS FROM "Bicycle-Engines.com" @ $49.99 ea, BOUGHT TWO OF THEM AND A THROTTLE CABLE TO GET THE FREE SHIPPING.
FREEWHEEL BEARING WOULD NOT BE NEEDED ON THE TIRE AXLES. THE TIRE THAT SPINS LIKE A FRONT WHEEL WILL NEED TO BE LOCKED TO THE AXLE IN SOME MANNER .
THEY ARE OUT IN THE SHOP, THINKING THE AXLE IS 1/2" DIA WITH TWO SEALED BEARINGS ON EACH SIDE, 4 BRGS TOTAL. THE HUB IS RIGHT HAND THREAD ON THE RIGHT HAND SIDE FOR A SINGLE FREEWHEEL SPROCKET OR A CASSETTE.
THE LEFT SIDE IS UNUSUAL!! BUT MAKES SENSE! LOL IT HAS A LEFT HAND THREAD NEAREST THE SPOKE FLANGE, AND A RIGHT HAND THREAD ON THE OUTER MOST PART OF THE HUB.
HERE IS THE RUB, THE LEFT HAND THREAD IS OVER SIZED TO GET PAST THE STANDARD 1 3/8" RIGHT HAND THREADS. I PURCHASED THE HUBS FOR THE LEFT HAND THREAD ADAPTERS AND 48 TOOTH SPROCKETS. I HAVE A DIE FOR CUTTING LEFT HAND THREADS ON MY WHEELS WITH OUT TAKING THE SPOKES OFF. LATER FOUND STANDARD 1 3/8" LEFT HAND THREAD ADAPTERS. SO I HAVE NOT USED MY HUBS YET.
THE HUBS AND PARTS WILL WORK PERFECTLY FOR THE TRIKE. THE HUBS COME WITH THE LEFT HAND THREAD ADAPTER AND A 48 TOOTH SPROCKET THAT BOLTS TO THE ADAPTER, ALSO INCLUDED IS A COMPLETE DRUM BRAKE SYSTEM. THAT USES THE RIGHT HAND THREAD ON THE LEFT SIDE OF BIKE. THE BRAKE WOULD BE LEFT OFF AND A RIGHT HAND FREEWHEEL SPROCKET SCREWED ON FOR DRIVING THE REAR WHEEL.
THERE ARE OTHER OPTINS FOR THIS HUB ON TRIKES ALSO.
THIS IS NOT NEAR AS COMPLICATED AS IT FIRST SEEMS. LOL.
RON
RON
