With a bike that looks that cool I myself would only use creative eng. parts on it motor mount, sprocket hub adap, and manifold.
Thanks for the compliments on my bike, but the brake situation (see my 2 posts just before this one) really has me bummed. After surfing this forum really good I think decent brakes are essential and I want them. Engine mount + good brake setup + all the custom fabrication required to have it on this bike = an entire new bike with decent brakes and an engine kit.I agree with CabinFever, DO NOT drill holes in your frame! You can buy exhaust clamps at your local auto parts store. Vice, hammer, and drill are the only tools you will need to shape a piece of steel to adapt your motor to your bike. Cool bike, I would do a Sick Bike parts shift kit and take advantage of the multi-speed hub. Never used one with internal geared hub but there is nothing like taking off from a stop light without pedal assist and shifting gears!
well since no one pointed this out. I have a electra coaster,and so does my father and i am sure you have noticed our bikes have a min of a 6" stretch to them. drilling a aluminum frame is a big don't, you really want to isolate engine vibration's if you don't you WILL crack the frame. i would really recommend a rack mount engine. and as far as the nexus hub holding out i have already rebuilt my coaster brake hub twice with about 200 miles
Thanks Antihista, I agree about the problems with this build too, but I wouldn't mount a ugly friction drive engine to this beautiful bike. I'll just keep it the way it is. I do want a bike with the low seat and forward pedals if possible though. I am now spoiled rotten on this comfortable set up. I'll just stick to the traditional drive system now that I have advice against using a jack shaft with the Nexus hub. It works fine for peddaling.RCinAL you are right in choosing a different bike the electras are really hard to mount a engine in them Jim's mounts will not work in the frame because they flex to much and WILL crack like i said a friction drive really would be your best option
