How many millimeters is a # 70 also a # 68. I'm trying to determine what drill bits to buy!! Maybe 0.3 mm. To. 1.2mm ?
This is the most perfect response ever!!I haven't chcked spark plug, Stock wire, Just got the motor, Always been like that. No mods, 24:1 ratio
Im having problems with my motor running without choke. It will completely stall out once i turn off the choke, No matter how long ive ran it. Jetting should fix this problem yes?[/QUOTe
Are you sure your not turning the choke on and killing it, my friend had it mixed up first few times out and asked me the exact same question. its not like its labeled so a easy mistake on his part. Since the engines are pretty rich right out of the box many wont even start using the choke in full on position.
choke on up off down.
Correct. Sounds backwards, I know, but that's how you say it.so the choke open is " off " and choke closed is " on " I just made my longest ride yet on it, It didnt do to bad, I just wish i had more low end. Trying to start at a stop light is horrible. I have to pettle a few times to get it going good, Is this normal ?
