Hi everyone. Having a good day? Awesome. So off to the question.. Ok It looked like i was having a leak around bottom of base gasket and a corner of my head gasket. I still think part of it still is but just would like to bat around a few ideas. First i thought it was my carb not being set right, so i set the float to recommended height. I noticed it was running nicer and just a little blubbery at 1/4 to 1/2 throttle. Looked at plug-choc brown. Next day, back to blubbery and running a little rough so i check head torque. 120 inch lbs and hasnt budged. I took off cylinder body and lapped those surfaces and even the head again just to make sure. Runs ok the next day but on the return trip it goes back to leaking. I can see a little gas mix coming out the tip of the weld when you look down and out a couple sides of the bottom gasket. I just replaced them with the copper ones from juice moto but they haven't seemed to seat from the get-go. Should i be looking at crankcase gasket or is it just mix from the leakspots? Its running and the plug still looks choc-brown(a little crap around it), but i have a slightly higher than norm idle that takes a few secs to come back. I could put on another base gasket but not sure what raising or lowering would do to it. ANY help would be appreciated and maybe one day i can solve one of your issues by pure luck haha thanks 70 cc flying horse/32:1 mix/replaced crank seals/ngk b6hs
