Hey map thanks for that very intuitive video on U Tube about removing excess weight from the piston. Question... do those holes have to be perfectly measured from the others Because the only thing I'm prefect at doing exactly... is exactly nothing
The wedging of the piston is what I'm trying to do now with an old piston on a used parts build I'm doing it for a "top speed bike" I'm going to use 7000C street tires that are thin, thin, thin, shaving weight here and there I wanna hit 50 MPH for the first time !!
I will worry about slowing it down after I hit the 50 M.P.H. mark So right now brakes are an unnecessary weight I do not want !!
Again thanks for the info!!
The holes don't have to be perfectly spaced between each other and as long as they're at least fairly close to the same I dont think it will create a problem, however.... it is very very important that the holes be drilled so that they are NEVER opened at all as they pass one of the ports whether it be intake, exhaust or the transfer ports, if they are it will create problems that will most likely cause terrible performance robbing issues and defeat the purpose of everything else that has been done.
Now I want to add some info here in regards to the holes being drilled in the piston I used in my engine.
The next one I do that way will only get 4 holes drilled in it most likely, one between each port and they will still be 3/16" in diameter, my reason for this is I'm not interested in going 50 MPH on one of my current bikes anymore, its just to dang fast on a regular bicycle and so I plan to build my bikes for low to mid 40's from now on, piston I have now that I drilled 12 holes in works great in the lower to lower mid rpm range and also works great in the extremely high rpm range, engine was very smooth running with very little vibes and very comfortable, BUT... yeah there is a big BUT to all of this also, and that is with the piston lightened as much as I did, the midrange 32 mph rpms got pretty rough so to cruise comfortably with that set up I need to keep the cruise speed below 32 MPH or run on up past that point to around 37+ MPH and then it will smooth back out from 37-38 MPH all the way to top speed in the higher RPMs and all the in between, it could be that this will not be the same with every Gen IV lower since the crank balance may not be exactly the same on each one, I don't think the slightly lighter piston actually added any extra top speed potential but it could have added a little possibly since the piston is easier to move being that it is lighter.
All I know is that I would rather have my engine deal with the mid range a bit smoother and not hit that growling rough spot in the low 30's since when I'm in town that is where I do most of my cruising and rarely cruise in the 40's in town accept for a couple of long stretches where the speed limit is 40 & 45 MPH.
Honestly I think notching the piston skirt on the intake side and changing port timing a bit by ramping piston @ exhaust and transfers is all that I will probably need to do to keep my bikes running at the cruise speeds I want and still have at least low to mid 40 MPH top speeds with all conditions being good.
Jumpa, I can tell you right now that 50 MPH on a regular bicycle is very fast and not easy to get done, you better have some good wheels, tubes, tires and brakes on that bike if it is gonna run those speeds, if not you could end up eating asphalt hard and fast....
I'm gonna try my drilled and cut piston in another Dax lower I have and see if that same rough spot exists at upper mid RPMs, if not then I'll know it was just the crank balance in that particular engine, but if it does it like the other lower I'll say that the piston was lightened to much for the mid range rpm's but is good for mid lows and upper highs rpms.
Be safe whatever you do Jumpa.....
Map
