here is what i have done to my stock black cat muff...
1 i cut the exhaust in two then cut off the cat converter, it was so clogged you could not even see though it when held up to the light
2 i then cut the headder tube that protrudes into the exhaust chamber bback to the verry begining
3 i cut out and removed the stinger pipe and drilled the hole out to fit a 3/4 inch universal glass pack.
4 i then got a exhaust pipe joint from auto zone that fit inside the exhaust chamber and welded it together effectivly extanding the exhaust 4 inches
5 threaded in the glass pack muff
6 paint as desired
the bike sounds a lot like a 4 stroke dirt bike with the muff on, with just a 1/2 id sstinger it sounds like a 50 cc 2 banger ... ring a ding ding ping ping ping.... so i leave the muff on cause i do not want to anoy my niegbors lol plus i notice no differance in power between the two so ...
the diff in power between stock and modded well... that is a huge diff ... i got verry noticable power everwhere and a lot on the top end !!! the styock cat was so restrictive you couldnt even see though it and it made the motor rev slow and make no top end ... now it rips !!!
the big hollow long tube after the header pipe acts sort of like a x chamber although its not as good as one properly angled and conned this stock exhaust now has a little band that comes on once you reach the upper rpms !
pics of mods ....
6 paint as desired
pics of mods ....
