I've got a wild inclination to start buying in Stock chinagirl 66cc motors, set them for high performance and reliability, and rell them to the community for a minor profit.
A lot of people have probably done this in the past and screwed up somewhere or another.
So, submitted for the community, the following:
(1) How much would you want out of a 'massaged' replacement china 66cc motor?
(2) How much would you pay for the above?
(3) Would anyone be interested in more expensive 'Hybrid' motors with Moped top ends and stroked cranks? Puch cylinders are close to being compatible with chineese bottom ends, except for a difference in stroke, 38mm VS 43mm crankshaft stroke.
The motors I'd be offering would come with a puch high compression head, BP6HS plug, balanced /stuffed crankshaft, Walbro 668 carb, reground front sprocket, corrected/widened ports (set for mid/top end power, gear down if you need torque) and Grade 5 studs/fasteners all the way around, with extra nuts and locknuts. Basically everything I'd do to one of my own motors.
On top of that, I'm going to be experimenting with puch kits and adding reed valves, boost porting, and auxilliary intake ports to a china 66cc. If I can get acceptable performance gains from modding a stock jug, that saves me having to get Crankshafts remachined and buy in new cylinder kits.
Thoughts, comments, criticism, death threats: all welcome.
