MotoMagz Well-Known Member Aug 2, 2010 1,817 1,154 113 Michigan Mar 30, 2016 #1 I'm looking for moped hubs primarily a rear with 125mm max spacing. Pm if you have anything 19" rims too!
racie35 Active Member Nov 17, 2012 1,702 5 38 usa Mar 30, 2016 #2 Keith, aren't the moped 19" tires and wheels closer to 24" bicycle than 26"? I know you said 26 when we talked but I'm not sure.
MotoMagz Well-Known Member Aug 2, 2010 1,817 1,154 113 Michigan Mar 30, 2016 #3 19" moped rims are close to 24" bicycle rims. My bike has 24" rims so it would be perfect.
chainmaker Well-Known Member Jan 19, 2010 2,634 69 48 Ma USA Mar 31, 2016 #4 Looks like they are back in stock (the chrome ones) I'd spend the extra bucks on the black aluminum ones, the reviews are right about the chrome chipping away. http://www.treatland.tv/new-19-x-2-25-chrome-spoke-rim-p/oem-spoke-rim-19x2.25.htm http://www.treatland.tv/semi-gloss-satin-black-NINETEEN-inch-rim-p/black-nineteen-inch-rim.htm This is the rear hub I have http://m.1977mopeds.com/item/3339313834 and it has provisions for direct bolt on sprocket Last edited: Mar 31, 2016
F FFV8 New Member Oct 29, 2013 551 16 0 Spring Valley NV Mar 31, 2016 #5 Now would be the time to buy all that stuff at Treatland - they are running a spring sale through Monday (4/4) with a 16% discount AND free shipping on orders over 150 bucks. Shipping adds up quick on rims. They have the narrow Tomos rear hub in stock: http://www.treatland.tv/tomos-OEM-silver-rear-hub-streetmate-and-revival-p/tomos-oem-rear-hub-232835.htm They should have the brake assembly to fit too.
MotoMagz Well-Known Member Aug 2, 2010 1,817 1,154 113 Michigan Mar 31, 2016 #6 Thanks guys I appreciate all the links. I have a few emails out to moped 77 and trealand.
LabRat New Member Dec 24, 2011 596 20 0 Ruston, Washington Apr 28, 2016 #7 MotoMagz Did you get your solution yet? Landed a can with MBK AV-7 rear hubs (110mm brake!)
MotoMagz Well-Known Member Aug 2, 2010 1,817 1,154 113 Michigan Apr 28, 2016 #8 I've purchased 90mm front and rear sturmey's hoping they will do the trick. If not I will revisit the moped hub scene. Thank you
