Hi,
About a year ago I bought a used bike with a kit already installed. Not sure if it's a 49,66, or 80cc because it was painted black and the identiplate on the clutch cover side is pained over and scratched up.
Rode nice for a while but always had an intermittent rpm control problem with it, i.e., at times with the engine being hot (or cold) rpm's would race high and out of control if I didn't stop it by using the kill switch or engaging the clutch to put a load on the motor.
I've got an expansion tube muffler on it and I believe an NT carb (you know the one with the red air cleaner cover). Side note, with the muffler off I looked at the side of the piston and there were visible vertical scratches that I could easily catch my fingernail on. Not good, I know. However, I've seen this kind of scoring before on small 2 stoke pistons but have not experienced high rpms like this thing is doing.
I've read many posts and have found many possible solutions as listed below, some of these I have tried but nothing has worked yet.
Possible Causes
1. low fuel flow. I removed the fuel hose from the carb petcock and checked the fuel flow from tank through the hose and into a bucket. It flowed but I wasn't sure if was sufficient. It seemed like only a trickle. Drained the gas tank and cleaned off the gas tank petcock filter. There was some debris on it. replaced it and the flow check seemed the same.
2. air leak. While engine was running and trying to control the rpms by slightly engaging/disengaging the clutch so it wouldn't run too fast I sprayed carb cleaner around where the carb meets the manifold, manifold meets the intake port, crank drive gear comes through the housing, magneto shaft comes through the case, and all around the case. Never heard the slightest change in rpms while doing this.
3. Main jet clogged. nope, and I lock-tighted it in a few days ago just in case and it's clear with no obstructions.
4. Wrong jet size? It's whatever came in that carb
5. Throttle slide stuck. I was actually looking down the intake side of the carb (with filter off) when the engine was trying to rev itself to death and the slide was as far down as it would go. The throttle opens and closes very freely.
Just scratching my head now so I thought I'd throw this out to anyone who cares to read this kinda stuff. Thanks for any help on this.
Rich
Possible Causes
Rich
