What do you guys think? Aluminum frame BMX bike build
JoelGSXR1000
Sac Town Cali
The build is going to be a GT Power Series 24" BMX cruiser. It has an aluminum frame and is an extremely light bike. I plan on running a Friction drive set up, either Staton or BMP if they get back up and running soon. I will be using a GP460 with a tuned pipe as the engine. I also plan on using a 1.25 drive spindle.
One concern that I have: Will this vibrate to a point that will be a problem. I have read that aluminum bikes vibrate too much with engines but have no first hand experience. Any help is greatly appreciated. Thanks Joel
Venice Motor Bikes
Mar 20, 2008
7,272
1,810
Los Angeles, CA.
I like it!... My plan is to use a aluminum OM Flyer for my next So-Cal racer! ;)
Aluminum frames are fine as long as you mount the engine very solid to the frame!
You shouldn't have any problems with a friction drive!
GearNut
5,104
11
San Diego, Kaliforgnia
The aluminum framed bikes usually have problems with the HT engines which mount inside the triangle of the frame. A friction drive should give you no problems.
