Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Mounting Techniques for Bicycle Motors
Mounting Techniques for Bicycle Motors Every frame is different. Share and ask questions about mounting your engine kit to your frame or rack
Old 07-01-2013, 06:08 PM
locell's Avatar
locell locell is offline
Exclamation Re: How To: Spreading Your Frame for Clearance
Originally Posted by 5-7HEAVEN View Post
Your advice is timeless, bairdco.
Here's my problem.
Dropout width is 130mm, so I can get a multi-speed hub in there w/no probs.
I need more tire clearance for my motorcycle tire. I'm estimating less than -1/16" on one chainstay to +1/16" on the other side's seat stay.
Do I have to cut off the fender bracket/cross brace on the seat stay?
Do I have to cut off the bike stand bracket on the chain stay?
To my thinking, that's the only way the stays will spread where the tire will be. I can secure the stays with C-clamps. That way, the welds on the seat tube don't get stressed during the spreading process.
Thanks for help. I'll prolly use a Toyota jack or all-thread and washers.
I'd use the all-thread method. the Jack Might spread it out a little to fast, and that could be a problem. The all-thread allows for some more precision control as well.
Old 07-01-2013, 10:03 PM
Default Re: How To: Spreading Your Frame for Clearance
Good point, locell.
Old 07-02-2013, 12:15 AM
BigBlue's Avatar
BigBlue BigBlue is offline
This is a technique by Sheldon Brown - those pictures in post #1 look familiar. Just check for symmetry with a piece of string, as shown by Sheldon Brown:
http://sheldonbrown.com/frame-spacing.html
Good Luck,
Chris
AKA: BigBlue
Old 02-08-2016, 11:41 PM
LabRat's Avatar
LabRat LabRat is offline
Originally Posted by Desert Rat View Post
This is the axle I'm using, and by time you mount it you do have to spread your frame quite a bit.
http://www.bicycle-engines.com/Freew...t-w-Brake.html
when I bought it I didn't think I would have to spread the frame that much but there you go, oh and I'm mounting a 79cc and ezm to it
That hub. Myself and everyone I know who has ever used that hub has had it fail. Good luck to you and your choice. I know of three failed HD hubs like the one you posted from the same place.
burp
Old 05-28-2016, 08:55 PM
Rocket123's Avatar
Rocket123 Rocket123 is offline
Here is the simple tool I made. Jamb nuts in the middle to hold from spinning then just turned the outer nuts. It worked for me.
MotorBicycling.com
