Sixze and wall thickness of stock exhaust tubing.
borntofli
306
tx
What size tubing do I need to get to weld in an extension on my exhaust???
It looks like 7/8" od and fairly thick walls....
Does anyone sell exhaust manifolds we can use for making our own??
2door
Moderator
Staff member
16,302
175
Littleton, Colorado
I've had good luck with 3/4" EMT, electrical conduit. Actually I made a tool to swedge the conduit so it slides over the stock, or 2 stroke, if that's what you have, exhaust pipe. I TIG weld it but a wire feed or MIG machine will also do the job. Conduit benders are available so you can fabricate the pipe to fit your frame.
Good luck and you'll get other ideas from members. And yes, the stock pipe is about 7/8" O.D.
