I don't have a whole design for a generator but there are plenty on google.
RC Generator
Wind power
Here are some links to the charging circuts.
Nicad and NiMH Battery Discharge Curves
SHDesigns - Lithium Ion Charger
Gell-Cell Charger
When you are looking for a motor to use as a generator keep a few things in mind.
Rewiring the coils at the ends can give higher voltage or higher amperage.
Your generator only needs to have enough power to run the charger.
Not alot maybe even the 6v white wire can do it.
I don't know.
Your batteries unless used for long periods of time will allways be charged.
Your lights will allways work.
Maybe even a radio.
They use these setups in RC planes and RC Helicopters that cost thousands.
Theese have very small engines in them.
I'm pretty confident this will work well for us.
I just don't have time to do all the research right now.
If you want to build the circut i can help you.
It's alot simpler than you might think.
The charger can be tested with a universal DC power suplly.
These chargers don't require a large input voltage or wattage.
PERFECT.
RC Generator
Wind power
Gell-Cell Charger
I don't know.
Maybe even a radio.
PERFECT.
