I have for sale a lot of parts from my previous motorized bicycle, along with a steel frame huffy. There are enough parts here to assemble a complete bike and have lots of spare parts. Among the notable parts includes:
2 Stroke HT engine in pieces, but all pieces should be there. Comes with two cylinders, two heads, two plugs, a piston pin bearing from the 66cc meaning little to no bearing play between the piston and bearing, new clutch pads, 2 CDIs, 2 NT carbs with size 66 and 68 jets, Complete new gasket kit, includes clutch removal tool. Comes with 3 mufflers and 3 metal exhaust gaskets. 2 Of the mufflers are port matched, one of the gaskets is port matched. The Curvy looking cylinder with piston have about 40 miles on them, the more square and dirty looking cylinder has about 2000 miles on it.
Mounting parts from 2 stroke HT kit, 4 stroke 4g(i think) kit, and 2 stroke SBP shift kit parts. Also includes assembly manuals for the Shift kit and 2 stroke kit. Gas tank from 2 stroke kit. Please note that the sbp shift kit parts will require new bearings and it appears that the one way pedal bearing is missing. Comes with 2 rear sprockets and 2 pedal sprockets, don't ask me to count the teeth.
Assorted pedal setups with crankshafts, bearings, sealed crankshaft, etc
26" Steel frame Huffy bicycle
Note: You will need a throttle and kill switch combo if you plan to use these parts for a complete bike, a new clutch cable will also be required.
$50 Takes EVERYTHING!
SOLD!
SOLD!
