http://www.pistonbikes.com/Motorized-Trike-Conversion-Kit-p/mtck.htm this is the kit I plan on using.
I know all the down falls of trikes I grew up on 3 wheelers my question is simple I just need to know what parts besides engine I need Ill worry about the dangers when I get it together. I ride in the city I dont have curves to worry about much and not looking for speed.
Yep, that is the 2 to 3 wheel bolt on I have read about.
Figure ~$400 delivered without any rubber but it has the 24" wheels and their own left side motor and pedal drive system, clever.
I think this is the outfit that makes the base and other options.
http://www.choppersus.com/store/category/1/74/Trike-Kits-Parts/
Specifically this base.
http://www.choppersus.com/store/product/740/Trike-Kit-Heavy-Duty-BLACK/
~$200 delivered with no wheels or transfer system but options for a 3-speed system.
If you want to go direct drive gas your choice looks to be the best.
A simple 2-stroke, 24" rear wheels and that gearing you should be able to hit your top speed mark but it'll be sluggish at low speeds.
As for using the GT2-A 2-stoke frame with the gas tank in it your list of 'other parts needed' in short is everything to build a bicycle up from a bare frame, I made a topic here with the specs and parts list this month.
Heck I have $800+ into to my GT2A-S bare frame 4-stroke 3-speed 2-wheel shifter not counting the engine and transfer case!
But considering your needs...
I am mainly building a couple trikes that my wife and I can go shopping ,cursing, and winter riding.
I suggest you go with an electric shifter kit on an already made 6-speed trike as I mentioned earlier.
No muss, no fuss, no smell, whisper quite, they 'start' with a switch on the throttle and Lithium Ion battery electrics LOVE cold weather.
Sick Bike Parts has everything but the trike and battery for ~$400 here.
http://www.sickbikeparts.com/catalog/index.php?cPath=26&osCsid=7il4bvtko24i4b5j9a8bo0stj2
You just need to pick a voltage (36 or 48V) and the newest LI batteries can bolt right on the bike and get ya 30+ miles before you need to charge them.
I am almost done with my 4th electric electric shifter, this one on a 6-speed Flying Pigeon adult trike with rear band brake for ~$400.
http://www.amazon.com/24-Adult-Tricycle-Speed-Trike/product-reviews/B008TOMXTU
I built a couple on the 7-speed Schwinn Meridian as well but you get the idea, why pay $400+ for just a bolt on kit when you can buy a whole trike for that?
The meridian was the better trike, it came with the frame as one complete trike unit with support struts in a HUGE box but have been discontinued, the Pigeon is their own Chinese design with a 6-speed and lever actuated band brake not a coaster so it's OK your pedals freewheel backward but the rear bolts on like those other kits.
I have pictures of the rear axle bolt on parts somewhere but I can't find them but it would bolt to most any 2-sheel bike as well.
If you want to explore electric trikes you will find this helpful.
http://kcsbikes.com/topic.asp?TOPIC_ID=566
This one even more helpful, my first electric trike build
http://kcsbikes.com/topic.asp?TOPIC_ID=497
These two images may help you picture how the motor power is transferred to the drive train easier.
Just food for thought as there are far more mechanical and customizing options with electrics than gas and I look like this when I ride my builds like this...
... especially when I pace 'Joe Spandex' pedaling his A$$ off on his $5,000 bike with a load in my basket sitting up straight and slowly pedaling backwards for effect ;-}
