Hi there
I was wondering about the above.I read on another forum that the tyre diameter doesn't matter. This is what the forum said:
"Wait a Minute! Doesn't tire size play a factor in calculating the top speed? With friction drives, No, it does not. With all other drive types, tire size does matter. Here's why tire size doesn't matter with a friction drive: The speed of the tire rotation in RPM is related to bike speed, but, it is really the speed of the circumference of the tire, in miles per hour, which is directly related to bike speed. After all, the tire is in physical contact with the road, and if there is no slippage, the tire circumference speed and the bike speed HAVE to be equal. Likewise, if there is no slippage, the tire circumference speed and the roller circumference speed MUST be equal, because THEY are in direct contact. Think of it this way - Essentially, the tire is just a transfer roller (or idler wheel,) between the drive roller and the road... A smaller tire would spin faster than a larger tire, but, since the circumference of the smaller tire is proportionally less, (by exactly the same ratio as the tire diameter, and the RPM increase,) there is no difference in bike speed."
Surely the tyre diameter has something to do with gearing using friction drive, and not only the roller diameter? Could someone explain this to me?
