Hello!
After building a rather successful 2 stroke motorized bicycle I thought I'll try to make something different like a belt driven 4 stroke motorized bicycle. I have got a lawn mower engine which I'll convert to run horizontally, it is a 3.5hp Briggs & Stratton.
I will use an old bicycle frame which is going to be chopped to fit that engine. I want to avoid using a jackshaft so the rear pulley will be a 26" bicycle rim fitted side-by-side to another 26" rim with a thin tyre. I'll try to find a small pulley to fit on engine shaft, 63mm diameter is the smallest I can find. Gear ratio would be 8.87:1, at 5000 rpm it should reach 43.6 mph. I have seen one like this on youtube so I remain optimistic about the gear ratio.
Please comment on my project so that I could work out all the flaws before starting to build.
