As I said that was my very FIRST build
This is the latest, And this one I can ride on the street too without hassle
Proudly sponsoring some of the best brand names of both bicycle and motorised bicycle companies around the globe.
Frame: Designed and Assembled in Melbourne, Australia Allegros Bikes M2 Frame 6061 Alloy Tripple butted tubing. Medium size frame.
Weighs bugger all, super strong at the joints, disc brake compatible perfect frame for the build. Not cheap as Aussie made. Goes for around $800. Happy to support local business though
Wheels: Custom 6 spoke magnesium alloy wheels. Best ones I could find had them custom made, almost same weight as 36 spoke heavy duty wheels anyway. Sealed Japanese bearings, quick hub release.
Never need to be trued, tough as nails and cool as ****.
Suspension: Rock Shox Reba Race Made in USA Compression, rebound adjustment. Awesome shocks, damn expensive though, service runs $120 here, $559 brand new.
Tyres: Semi Slick 2.35inch tyres with heavy duty thornproof tubes. Not a puncture or flat to this day. Best tyres IMO as on road they ride on the centre flat, the knobs provide stability when cornering and yes of course offroad is an option, especially with the shocks
The Engine and the Rest:
When I say this is build from ground up I mean it. Blank Castings purchased and machines by ScreamingRoo in Perth, Australia.
> German Made C3 anti vibration bearings fitted
> Computer Balanced Crank
> Modified CrankCase
> Stainless Steel HT Head Studs with 12.9 HT Nuts/Lock Washers
> Hellicoils Fitted to studs (Basically impossible to ever over tighten head studs or strip or break them)
> 12.9HT Grade Cap head bolts all round.
> Custom quiet clutch/gear setup with machined clutch face, clutch arm ect.
> Hardened and machined crank rod and Japanese Made crank bearings
> JN Motors Experimental Reed cylinder. (The most aggressive cylinder work I have ever seen, took a chance and it bloody paid off)
> Juice Moto Titanium Wrist Pin bearing (Lightens piston setup)
> Bronze Wrist Pin Bushing (Best to use with lightened setup, gives (debatable) higher RPM + DOES give better reliability.
> JN Motors Experimental Reed Piston, Lightened with Custom Machined Window and cutouts, super light perfect for reed setup.
> CR Machine 5.8cc High Compression Competition Billet Aluminum head
> Juice Moto .16'' Custom Copper Head Gasket. Never a leak, transfers heat to massive cooling area of head, plus increases compression.
> NGK Iridium Spark Plug Heat matched 8 series
> Billet Aluminum RSE Reed valve, big shoutout for Tony at RockSolidEngines for this custom setup. (Yes I know its not crank induction but I wanted something proven and yes this does the job bloody well, plus I can use a walbro carb )
> Billet Aluminum Walbro HP3 Carb, not your average small walbro. Custom machined big venturi. Independent High/Low needles for instant best tune. Never leaks, never gets clogged. Revs like no tomorrow.
> Billet Aluminum Velocity stack with custom throttle setup
> Unifilter Air Pod, Custom made for RSE. Great stuff.
> Billet Aluminum Exhaust Header, all custom port flowed into the:
> SBP Nickel Plated Exhaust system. I went over the entire exhaust even taking quite a bit of material off for more flow. Once again, a proven system.
> Go cart polyurethane Fuel Line
> 2.5lt Custom Matt Black Fuel Take
> SBP Chrome High Flow Fuel Tap and gauze
> High flow pit bike fuel filter
> Pit Bike Air vent for fuel tank, no overflows or leaks now really recommended mod.
> Pit Bike 1/4 Turn Billet Alloy throttle assembly. Amazing throttle response especially with walbro carb
> Pit Bike Kill switch assembly
> Custom flat bar 6061 Handlebars with billet spacers, Japanese headset bearings.
> Digital Speedometer with Odometer, time ect
> Dual Alloy 8 LED Headlamps
> Chrome Clutch Lever
> Rear View Mirror (Comes in damn handy)
> Alloy BMX Custom Grips (To match Red/black theme of this bike, yes I go for Essendon (Red/Black team colors)
> Alloy Dual Brake Lever
> Chrome Tyre Caps (Yes the LED ones that make a blue ring around the wheel when night riding, just like the TRON movies
> 8 Speed alloy thump shifter, have tried grip and this one is so damn easy, plus a great click when shifting.
> HD Lightning CDI
> Upgraded Coil Pack
> Super Magneto courtesy of ScreamingRoo. Custom made for them. DOUBLE coils, MUCH higher voltage produced no "white light wire" just pure power.
> MSD Made in USA Superconductor Spark Plug Lead
^ These plus the super magneto, ngk iridium make the best spark Ive ever seen out of a bike motor.
> SBP HD Shift Kit (upgraded freewheel ect) plus all the goodies chain break, crank tool ect, came in really handy
> SBP RHS and LHS Chain tensioners, a must have not just for alignment but for less adjusting the chain
> GOLD KMC 410 titainium pin, alti drop, leightweight, ect ect best chains I could find
> Same GOLD KMC 3/32 rear chain anti stretch, anti drop, cutouts, ect ect
> Shimano Nickel Chrome Plated rear cassette 32-11 (28t second gear is used to get from 0 to around 25kmph in a snap)
> Shimano Once again Japanese made Ultegra 6500 Chrome rear derailleur short cage ideal for single chainwheel.
> Jagwire Custom red cable/crimp set, less friction, cooler looks and lighter as well
> Rear LED 8 Mode Taillight
> Custom Dual Spring Seat so damn comfy.
> Oh year and the:
Avid BB7 (Best Mechanical Disc Brakes)
+ Avid HSX Rotors ($80 a pair) head shedding disc brake rotors, amazing for downhill runs when im not flooring it
+ Chrome Crank Arms
+ Billet Alloy Pedals
+ Heaps of other stuff
Runs 50:1 98 RON Octane Fuel to Motul 800 Full Synthetic 2 Stroke Oil, Also have some great redline high rev 2 stroke stuff that I use too.
Let me know what I missed and bombard me with questions.
Done 250km will pull 80kmph with ease, to scared to try anything over, $1700 fine and 2 years suspension for driving one of these that fast here in VIC, Australia.
Vid Coming
