The only real way is to use the rag joint- unless it is a high flanged hub, and not already drilled with slots.
The hub is still a blessing- the sprocket gos on over the threaded section- way ahead of the game on many wheels-
A lock ring may help keep it on, but unless the motor sprocket is THREADED on a lockring will not hold it in place. I searched all over the world for a regular fixed track cog when I began to motorize, that was large enough to be of motor use- really "no go" - no one really makes a thread on cog larger than the small 20's in number- you may find a 24- still too small.
The best solution I've come up with is to find a fixie wheel or hub- a "track" hub if you will- that's threaded on both sides nut that has UNDRILLED smooth LARGE -FLANGED sides and drill the hub in the "six inner hole" pattern- also called the "disk brake" drilling"
and bolt the sprock directly to the hub- This saves the weight of the rag joint plates and the rubber pieces, and you can even use titanium bolts if you're really weight conscious. You could also use a rear disk brake hub, that has bolt on fittings already in it, but I've yet to find one that wasn't a CASSETTE as opposed to a freewheel hub- I still prefer a freewheel myself
You can get a built-up fixie wheel in 700c for about $70, but then you have to use a freewheel- one speed or multiple cog- and have handbrakes.
here's an old thread of mine about it- I've since gone to smaller alloy sprockets bolted on- it works great and reduces the sprocket and assembly weight to next to nothing:
http://motorbicycling.com/showthread.php?p=234139
