It seems I may have another problem with my new 68.5cc engine. With just over fifty miles I noticed a “clanking” noise coming from the primary clutch cover. I don’t get this noise on my 49cc so I popped the cover off and noticed right away that the crank gear is way off center on the clutch primary gear. (a hair over 3mm) This can’t be right so I popped the cover off on the 49cc just to make sure and my suspicion was confirmed. Its not that way on the 49cc. The two gears mesh properly and are in almost perfect alignment with one another.
If anybody has run into this problem before or knows how to get this gear in closer to align with the clutch gear I’m all ears.
I’m not gonna start tearing this thing apart until I find out more about it and I don’t believe it’s a good idea to ride the bike this way cause already I see some slight abnormal wear on the gears.
The first pic is of the 49cc primary and drive gear. The alignment is perfect. The second pic is of the 49cc but a different angle. This is the way it should be on the 68.5cc but its not.
The third and fourth pic are of the 68.5cc primary and drive gear. As you can see its way out of alignment.
RPM
RPM
