This bike most recently was setup as a DIY rear rack friction drive. I didnt care for the friction drive w/ the high powered engine (bad tire wear) & changed it to a more efficient V-Belt drivetrain.
I mounting this pocket bike engine on a lightweight, strong, aluminum rear rack using 1/4" aluminum stock & some 1/2" thick rubber skateboard riser pads as motor mounts to absorb vibration. I'll probably need to flip the handlebars upside down to get more weight onto the front wheel for handling purposes. Here are some pics of the mostly completed project. Check out the cable connection I made using a brass spoke nipple & some silver/lead solder. Instead of having to solder a new end to fit into the throttle slide, I simply cut the too short 42" cable I had, cut a new cable to fit into the brake lever throttle controller & soldered the two cut ends into the brass spoke nipple. Works great.
-Lowracer-
-Lowracer-
