what do you guys think if there where a kit available that could port match your intake and exhaust ?
it would be machined out of 1in thick aluminum bar stock and be an adapter to go on your motor over your ports before bolting your intake and exhaust back on and it would port match them for you!
all it would be is a 1 in thick al block cnc milled to match the intake ID and one milled to match the exhaust header ID then the other side of the 1 in block would be cnc milled to match the intake and the other the exhaust port.
the kit would provide you with longer high grade hex bolts to replace your cheap studs and a small sheet of gasket paper with the pattern already drawn on it for u to cut out and use. it would make all 4 gaskets.
all you would have to do is unbolt your exhaust and header tube then remove your exhaust and header studs, then cut out your gaskets and attach the adapters to the motor with your intake and exhaust.
and boom instant port match with a smooth 1 inch transition !!! the exta inch on your intake will help low end power and increase intake tracct volume and the extra inch on your exhaust will help take off power by moving the exhaust back a little
does this sound like a good idea ?
the thought came to me .... what if people who dont ave a dremal or do not know how to do this stuff want to port match there motor ? what do they do ? well a 1 inch spacer that port matches your intake to the intake port for you would help and the same for the exhaust should be true too right ? they should be fairly easy to make and pretty cheap to since i already have accses to 2 milling machines and 3 lathes !!! my dad lol i could make them easy
is this something people would want ? let me know i am going to make them for myself antway since its nearly impossable to correctly port math this motor without some kind of thick transistion material to make the shape change ...
pics
pics
