48T Sprocket Diameter?
runnermike
936
Sanford, FL
If anyone out there has a 48t sprocket, can you measure the diameter? I am trying to figure out some things on my current build. I am wanting to know before I purchase one.
Thank you very much!
curtisfox
6,048
3,959
minesota
Re: Can someone help??
How about the chain is spaced 1/2"x 48= 24" around would that be close enough......."...Curt
bluegoatwoods
1,581
6
Central Illinois
I don't have a 48 tooth.
But let's suppose that you have a 44 tooth. It would seem that the diameter of the 48 would be the diameter of the 44 X 48/44.
So if you've got a 44 you can measure, then you should be able to calculate the diameter of the 48 from that.
runnermike
936
Sanford, FL
Curt was correct. Take the circumference and divide by pi (3.14). I was flustered earlier and didn't think of it. I just tried it on another sprocket I have laying around and it's spot on.
Thanks
Davezilla
2,705
10
San Antonio Texas
Hmmm... 24/3.146 = 7.64
I'm thinking the 48 tooth is slightly bigger than that... But I just ran out to the garage and measured my 44 tooth at just around 7" so it's really close...
The_Aleman
2,653
You guys have it. I was asked this question in the chatbox a week ago, it's a simple formula:
Teeth count * Chain pitch / Pi = general sprocket diameter
I had to figure this out 2 years ago when I needed to put a 76T on my pedal cranks for my shift kit's engine reduction. I ended up going with #35 instead of 4x/4xx as I didn't want to have a 12" diameter sprocket! :D
76 * 0.5 / 3.14 = 12.1"
76 * 0.375 / 3.14 = 9.08"
