G'day Guys,
Integrity of your electrical connections is essential. The nature of electrical energy is that current flows at the outer surface of the conductor. One term for it in trade is "skin effect". The larger the cross sectional area of a conductor, the higher the current capacity of that wire/cable.
Another tip: When you use crimp terminals, DO NOT solder them. They are actually designed to be crimped and function better when crimped. If you solder them, you will find that (due to the amount of heat you need to apply to get the solder to flow on the crimp terminal) solder wicks it's way up your wire and makes the wire itself rigid. If you use the appropriate position on your crimping tool, the joint will hold and last just fine. Just look to ensure that when you strip back the insulation, you don't strip it too far or it will "bird cage". This will weaken the mechanical integrity of the electrical connection and reduce the current carrying capacity of your wire.
Brett.
