I built a bike with a 34cc craftsman chainsaw motor which is basically a 34cc poulan. I took the engine out of the case and built a motor mount using the crankcase cover bolts and have it mounted on the rear of my 26" mountain bike.
Since removing the case i have lost the pull start. I figured I would just friction start by petaling the motor and then releasing the clutch however the engine is acting like it has too much compression and the roller just slides on the tire during compression and does not turn.
All rollers have been around 1" and I have tried solid rubber, a smoothe socket, a socket with rough weld all over it, two strong springs, high tire preasure. The roller still slips on the tire and I cannot start the bike. Even the original pull start was tough to crank. Any ideas on how I can start this darn thing?
