After putting less than 200 miles on the Roadmaster mountain bike, it quickly became a nightmare to maintain. The last straw for me was the left pedal stripping out and leaving me stranded more than ten mile from Home....-Had to call the Misses on that one, found it too far to walk with Bike in hand. I'm not going to Bash the brand... I guess you really do get what you pay for.
With that repair being enough to make up my mind, I decided to use an old 27inch frame I had upset my wife enough with already, (it laying in the yard, sheltering weeds).
A rusty set of rims from a yard sale. My motor from the "diseased" mountain bike, front fork also (big guys gotta have cushion!). And as many other parts that I could scrounge up without spending anything other than for a Can of spray on truck bed liner for a matt finish, and I am much happy with the results...
The most enjoyable part of this build, was using as many of the parts I already had, either in the shed, or laying around the yard- too build something a little more reliable.
In case anyone is curious-The front headlight is a Led Headband type lantern mounted inside a all purpose fog light with a piece of plexiglass used as a lens to allow room for the batteries, and switch. -The output is somewhere around 115 lumens- plenty of light to ride by, and about 12-18 hours of battery life. I added the two small led flashlights at 25 lumens each just for overkill.
The Tank is Fiberglass and resin over a stock BGF tank. Add epoxy for lines.... Truckbed liner spray on top...and an easy durable finish to a custom tank. BTW- the Truckbed liner spray is a timesavor for anyone wanting to finish a tank in a Gas resist material- as long as you like matt finishes.... Each to his own!
-Comments are Welcome...
Richard-
Richard-
