Anyone recommend a front disk brake kit thats not going to break the bank? Switching over from rim brakes to disk brakes on the front.
Not to contradict you, but the third item down is a universal caliper mount, all he'd need is a wheel that sports disc brakes thenYou'll need a hub and a front fork that are compatible with discs. The fork will need caliper mounts and the hub will need to have mounts for a rotor.
And a fork wide enough to clear the rotor. Not every fork has that width.Not to contradict you, but the third item down is a universal caliper mount, all he'd need is a wheel that sports disc brakes then
http://www.pedalchopper.com/front-brake-solutions-occ-schwinn-stingray/
