did you push the primer button 3-4 times then try and peddal the bike 100 feet @ 10mph, then release the clutch and keep pedaling until it starts then pull in the clutch and idle it with some throttle to keep running.plus the choke lever should be in up position when starting unless its real hot outside,then leave lever down.also is you gas petcock in the on position.
