How much punishment can a multi-speed freewheel take?
midwestmayhem
79
southeast S.D.
This morning I woke up, poured a cup of coffee, and looked out into the patio to see my 5hp Robin bike. Then a question popped into my head. There's plenty of people out there with kit bikes powering the multi-speed freewheel. And a few like me who throw the power and torque of much larger engines at them, keeping our fingers crossed and the bearings greased.
So how much can a multi-speed handle? If and when they do fail, what is it that usually goes first? (sprockets, chain, freewheel itself, etc..)
5-7HEAVEN
2,661
240
There's only one way to find out.....DO IT!!
I've used 5hp 460 and ported Tanaka 47R engines thru the shift kit and 8-speed cassettes. I've broken many chains and wore out one cassette. This was all my fault, thru trial and error. All parts were standard-duty, not heavy duty or pricey.
The key to it all is to ALWAYS pedal a few seconds before, during and after shifting gears. Pedal for a few seconds from a standing start. Roll into your throttle at all times. IF you skip 2 or 3 gears at a time, it'll be a smoother engine power transition.
JMO, baby your shifts and do your preventive maintenance. You shouldn't have many problems.
Just do it!dance1
wheelbender6
4,059
221
TX
I would use a freewheel gear cluster instead of cassette. The parts that wear out in a free wheel gear cluster (bearings, pawls) are easily changed (with a freewheel tool). When using cassette gears, the bearings and pawls are in the hub, and not easily replaced.
Freewheel gear clusters are usually limited to 7 speeds.
BigBlue
781
California
A lot of recumbent trikes use multi-speed freewheels and many of the electric motors they use have a lot of torque. Check out Endless-Sphere.com forum.
You can buy a 8 and 9 speed freewheels. They are 40mm and 40mm +/- .2mm wide, respectively.
Make sure you don't mix-up the terminology between multi-speed freewheels and cassettes. See: Traditional Thread-on Freewheels
Removal of multi-speed freewheel requires the same tools to remove a cassette. A 10mm allen key is required to remove a freewheel hub from a cassette system, but not a multi-speed freewheel.
If you are interested in taking apart a single speed freewheel or a multi-speed freewheel, check out: Bicycle FreeWheel Basics
There is a special grease fitting made to grease your multi-speed freewheel. You don't need to take it apart unless you like to - just because you can.
Chris
AKA: Bigblue
