79cc predator mounting angle
58er
59
6
Michigan
does anything special have to a 79cc harbor freight motor to mount it so the cylinder is straight up other than intake and leveling of carburetor?
like removing low oil sensor.....etc.
thanks
racie35
1,702
5
usa
You wanna make sure the oil dipper is still dipping in oil,so a different amount will be needed...I think a few more ounces on that one...not sure.
I'd also lose that pipsqueak carb and replace with a slide type..maybe 16mm
FFV8
551
16
Spring Valley NV
Remove the low oil sensor. Plug the hole with a nut & bolt.
Remove ALL of the governor parts. remove the nylon gear, lever, etc. from inside the crankcase. Plug the lever hole with a bolt.
We run PZ 19 carbs on them. Big performance increase.
58er
59
6
Michigan
will the governor still work if not removed? just curious.
can the low oil sensor just be unplugged?
thanks
Dulcijo
29
North Carolina
I have been running a predator straight up for several hundred miles. I threaded and put an oil plug in the oil outlet commonly blanked. I unhooked the governor from the throttle but nothing really inside the crank case and she will wind til she blows up I think. I put a regular 2 cycle kit carb on the predator and it works real good. I never would have thought I could run that engine straight up like that for so long and had such good results.
58er
59
6
Michigan
Bought 79 cc engine. Tore apart but noticed with the cylinder mounted vertical. The oil fill hole that would normally be pointing up ( or in the top at this mounting angle) is not drilled out and tapped.
Any ideas?
racie35
1,702
5
usa
I didn't have that problem with the 212 but I think you're gonna hafta drill and tap
