Jaguar is Finished
2door
Moderator
Staff member
16,302
175
Littleton, Colorado
There's been a couple of questions about the lights used on the Jag. The headlight is from a 70s vintage battery powered emergency egress light. The kind used in commercial buildings to illuminate an area during a power failure. It is a 6 volt, 20 watt sealed beam. The tail light is an aftermarket hot rod item which was originally 12volt. I simply changed lamps. Power for both is provided by a 6 volt, 6.5 amp hour SLA (sealed lead acid) battery. When I took the first pictures of the finished bike I had not yet installed the battery because I was in the process of fabricating a plexiglass box to house it. It mounts under the seat just behind the lay-back seat post and a small rocker switch is used to switch the lights on/off. I tried to run the tailight from the white wire but in tests I could discern a slight rpm drop with the light on so I opted to use the battery instead. I've tested the run time and can get a full hour of good light from both lamps on the battery and that's enough for the amount of night riding I typically do. I use a small trickle charger to keep the battery charged. Hope this answers your questions and thanks again for all the kind words.
ShawnMac
11
Pittsburgh PA
Tom, I'm very impressed with your ride.
I just bougth a Jag yesterday that I'm planning on doing up for her. Where did you get the paint? Is it spray bomb? If so what brand / color; it looks to match perfectly?
Is your exausht pipe chromed or just polished?
thanks!
