I just wired up an LED headlight that seems to work. I have not tried it at night but it is surely bright enough to be seen.
All it is, is a 10 ohm resistor and a 1W LED wired in to the killswitch wire. This is an always on headlight. At idle, you can see it pulse with the engine strokes.
I gots the stuffs here:
1W Warm White High Power LED
Star LED
Part Code: STARLED_1W_WW
$2.90
(note: I used the warm white LED, either white LED should work)
10 ohm 1W resistor (10 pack)
Resistors 1W
R010R1W
$0.40
I am using a 1/4W resistor, but will switch to a higher wattage resistor, since I am pushing about 3V (drop) x 0.33a = 1W.
I calculated a 10 ohm resistor as follows
Assumed a 6V average voltage coming off the killswitch wire.
The LED needs 3.3V and uses 0.33a.
6V - 3.3V = 2.7V which is the desired drop across the resistor.
2.7V / 0.33a = 8.1 ohms
The closest resistor I had in my box was 10 ohms, which seems to do OK. The reality is that the killswitch voltage is a pulsing voltage, actually an ac voltage, but the LED is a diode so it allows only one leg of the ac through. So the result is a pulsing dc with an average (guesstimate) of about 6V. LED's can take a certain amount of pulsing but the real test is real life, you can only get so far with math equations. Time will tell if 10 ohms is enough.
So for less than $4 you can get the electronic parts to build a headlight.
Solder the resistor to the star on one of the positive pads. Connect the resistor to the killswitch wire. Connect one of the negative pads to the ground, or frame of bike, if that is what you are using.
I mounted the headlight by using 14 gauge solid copper wire, and wrapping the wire around the bike frame in front two turns, then secured it with a zip tie. These 1W LEDs are directional, so you don't really need a case and mirror to focus the beam forward.
Be aware that the back of the star has voltage, so cover it with electrical or duct tape to insulate it.
My bike is kind of a rat rod type, not too concerned about style. An LED with wires wrapped around the frame fits my Siberian Space Junk Collector theme.
There is no reason you could not use a red 1W LED in the same way for a taillight.
There is also a 3W Warm White LED. That may also work, but you might be pushing the power that your motor can deliver, and you would have to increase your resistor power rating.
Star LED
$2.90
Resistors 1W
R010R1W
$0.40
