I have a GRUBEE 2011 SkyHawk GT2 48cc Angle Fire Slant Head Bike Motor Kit.
1- I have carb problems fuel is leaking from the vent tube
2- The line that goes from the throttle to the carb that needle has no grooves for ring, like others i have seen on youtube, does that matter?how do i put that back together witch way does the washer thing that is shaped like the aris ram does it need to be alighned with the slot or not and what gas/oil ratio should I be using, I had the motor running for two weeks and it started with 16/1 ran for a full gallon then switched to 20/1 and then near half a tank engine seized up, so I took the cylender body off and the head and cylender body was scratched up, so I sent that back to get a new one, what oil/gas ratio should I be using?
3- How do you adjust the clutch in detail?
4- It squeals when clutch is out quitens down when clutch is pulled in (and when I mean pulled in, I mean from the handle grip pulled in)
