Did you ever consider disengaging the clutch before you pull?I would like to put the pull start back on, so the shift weight is what I do to pedal start but the pull start is to hard tho.Any other suggestion would help.
I'll get some head gaskets next time I order.I'll try that Aleman, thanks..If you can decrease the engine compression a bit you'll end up with slightly easier starting. Kind of a wonky way to do it, but 2 headgaskets might do the trick.
